Wondering if anyone can help me with this, please?
[1] The flash doesn't pop up when I press the button - I've had that problem before with the 550D, when I used to get an error code with it and it was apparently a common problem after using an external flash. That was easily solved by pushing the button and getting a fingernail under the edge of the flash unit.
[2] I go into the Flash control menu to enable flash firing - fine so far
[3] When I try to get into "built in flash function setting" I get the error message "This menu cannot be displayed. External flash is attached".
I'd be very grateful to hear if anyone has any ideas.
