Slave flash
  • Slave flash
    Put this on beginner's help as I suppose I am a beginner with this :-)
    What, realistically do I need for close up work with respect to flash? I have one of these nice wee mini studio thingummybobs but still getting shadows (albeit small ones). I therefore reckon I have to have lighting sources at the sides (or top) as well? I cannot for the life of me remember what I did many years ago with my old pre digital cameras for using slave flash. I cannot even find my old camera bag that had all my OM gear in it
    Also, I suppose related, what is a pretty good macro lens for the Nikon D90? Nothing over expensive mind :-)
    Just because cliches are cliches does not make them wrong. I do like walking in the rain.
    Re: Slave flash
    A very typical macro flash set up would have two heads on either side of the subject. The flash units would need variable power as you don't need that much power for macro work.
    I'll dig out a shot of a setup I have (thanks to our hire business!) but have yet to use...
      Re: Slave flash
      Here it is:
        Re: Slave flash
        Here it is:
        Looks a good setup Ian.
        Here is mine with a Sigma f2.8 105mm Macro lens and Sigma ring flash I can recommend both, there are Nikon versions off both.
        The Ring flash is highly controllable, including left and right independent light control, plus you well you name it.
        As a matter of interest I have used this setup for Head & Shoulder portrait to great effect.
          Re: Slave flash
          Wow Ian, that's the Oly twin flash. That's huge!
          I use the Oly ringflash that is about the size of the Sigma shown but not as adjustable side to side.
          My most used set up is the home brewed foam ring flash. A small flash fired into a roam ring as a diffuser.
          It allows me to get into bushes and extremely close.
          I'm actually planning to add a small slave flash on the side of my setups to introduce shadows to my set ups.
          Jim
          The Bug Whisperer
            Re: Slave flash
            Thanks for showing, Patrick. Of course for portraits you get doughnut catchlights
              Re: Slave flash
              Hmm, all look cool and pretty damn impressive. I was more thinking of things I have to have that are not attached to the camera if you know what I mean.
                Re: Slave flash
                  Re: Slave flash
                  What are using for flash now?
                  Are the shadows being caused by the lens?
                  Most inexpensive slaves are triggered by your on board flash. Or if you want, get a cord and use a small flash on it.
                  Jim
                  Jim
                  The Bug Whisperer
                    Re: Slave flash
                    Using a Nikon Speedlight at the minute. Don't think shadows are caused by the lens. More experimentation I guess.
                      Re: Slave flash
                      The Sigma 105mm Macro is an old-ish design but highly regarded and I think Patrick uses one. It's also great value.
                        Re: Slave flash
                        On advice of the gentleman in the shop I went for the Nikon 60mm f2.8. Need to start playing with it now :-)
